Use "this one simple trick" to reduce vertical banding
Posted: Mon Jun 02, 2014 11:37 am
(Sorry, couldn't resist the headline)
So, you upgraded to an E3D-V5 or V6, and you're noticing vertical banding and moire patterns on your prints?
Run your hotend fan(s) at 7V, and it should reduce or eliminate them.
To see if this fix would work for you, try this simple experiment:
You get it from the difference between a +12v line, and a +5v line.
However you'd like, wire your fan positive (red) to a +12v (yellow) line, and your fan negative (black) to a +5v (red) line.
I wouldn't do this with any type of high load device, but PC builders have been doing this for years to quiet down case fans. Driving a fan like this should not adversely impact your PSU. When I do this, the fins on my hot end aren't cold anymore, they're only a bit warm. I don't anticipate any cooling or jamming issues with ABS. Probably with PLA too. YMMV, so experiment a bit to see what works for you.
While it does reduce airflow across the cooling fins a bit, it's still plenty to keep the your hotend cool after the heat break, and I can't feel any vibrations on the build plate anymore.
I'm going to run a few parts like this shortly to verify, but this may be the root cause for the vertical banding and moire patterns we're seeing.
- with your hotend and build plate off, put a couple of fingers on your build plate. Is it vibrating? If you have vertical bands in your prints, it probably is, if you have magnetic arms and an E3D, then it definitely is. Your hotend fan(s) are sending vibrations up your arms, through the aluminum extrusions, and down to the build plate. When I installed my dual E3Ds, using bubbasnows mount with two fans, the moire patterns got worse.
- now, however you'd like, turn off your hotend fan, keeping everything else on, and try again. If your build plate stopped vibrating, you may benefit from this simple mod.
