Tower mounts do not have limit screws
Posted: Tue Jun 03, 2014 12:18 pm
by hagemeyp
My top tower mounts do not have limit or extrusion end stop screws. How far should I insert the AL extrusions before tightening down the Allen bolts ?
Re: Tower mounts do not have limit screws
Posted: Tue Jun 03, 2014 12:27 pm
Are the screws missing or are you building a V1 machine?
Posted: Tue Jun 03, 2014 2:44 pm
by hagemeyp
It's a V2 with recent design change. Is there a space to put the screws that I'm missing?
Posted: Tue Jun 03, 2014 3:02 pm
by geolupulus
The red oval indicates where the screw goes. It's different in that its the only part on the entire machine where a screw goes into a non-round hole. I found it easier to set the screw into the vertical support by pushing the small phillips screwdriver into the hole where the screw goes and turning it, sort of like a drill. That helped in getting the screws into the hole easily.
