Hotend too cold, I think.
Posted: Thu Jun 05, 2014 10:40 am
I have a Rostock Max v2 with standard hot end and everything was printing fine from the start. First print or 2 failed simply due to bed adhesion, (Prints came loose half way through). After switching to ABS slurry to hold everything down I was getting good prints. I even managed to print at .15 layer height for about 6.5 hours on one part and I was getting pretty good results. Alas, this has come to an end.
While printing a few small items the print came out all patchy and I noticed that the filament had been shaved down by the EZ Struder drive gear. I assumed I had a blockage and proceeded to remove and clean the nozzle. Upon re assembly I was still not getting any filament out and the end of the filament just above the nozzle had backed up and swollen so it was now stiff in the feed tube. Nextly I removed the whole hotend and cleaned and reassembled everything and tried again, still nothing.
I increased my temps to 245 and initially the print was coming out ok but after about 30 minutes or so it went patchy and the extruder again had failed to push the filament through. So I disassembled the heating resistors and thermistor and they all checked out with the multimeter. I wrapped the resistors in foil, for a more snug fit and reassembled everything nicely, only putting sealant on the ends to hold the resistors in place. Feeling rather pleased and very hopefully I tried again and sadly nothing.
The Extruder motor will happily feed filament and it takes a fair amount of force to stall in via the manual feed wheel which makes me think it is working well. If I feed filament down to the nozzle manually it takes quite a lot of force to push anything out the nozzle, even when I set the nozzle temp to 245C via Repetier Host.
I had the need to order a new thermistor from SeeMeCNC so I ordered 2 as I live in Ireland and the delivery times suck and both the installed one and the spare test to the same resistance roughly, (112kOhms - Installed, 113kOhms - Spare), the two resistors were reading about the 6.8ohms individually, my multimeter is cheap but it somewhat reliable, and about 3.8 ohms in parallel. I ran the PID autotune after reassembly each time and the values I now have are,
Kp: 24.246
Ki: 1.670
Kd: 88.33
The hotend appears to be too cold to extrude properly even at 245C, I am unsure as to whether it is a problem with the displayed temp, power of resistors or maybe an error in the controller. I am thinking that swapping the thermistor would rule out that but I feel since it tests the same as the spare at room temp that this may not be the fix. I have changed very little in the way of settings other than playing with fill and layer heights a little, is there anyway to push the nozzle temp beyond 245 to see if I can improve the extrusion? Any idea's on what to try next would be appreciated.
Kp: 24.246
Ki: 1.670
Kd: 88.33
