Print job stopped cold at M105 *10 request
Posted: Sat Jun 07, 2014 12:46 am
by Gr8Scott
Not sure why the host decided to check the temp only at exactly 30 minutes into the print job for the first time that I can find with a quick scroll back
I don't understand why the log file is showing the *10 after the M105 request exactly... That doesn't make sense to me as the request seems to be confusing the board in a very big way.
FYI - I have a 12v squirrel cage fan blowing like a hurricane onto the RAMBO with heat sinks on all active driver IC's. This board should be as cool as the veritable cucumber.
Re: Print job stopped cold at M105 *10 request
Posted: Sat Jun 07, 2014 1:16 am
by Gr8Scott
Found a setting in Repetier Host Firmware that looks as if it will stop the printer until the user presses a key. I disabled that and I'm going to see if I can make a print go past 30 minutes for a change LOL.
Well that was a bust. Seems as if the program is dying on me via the USB communications, so I'm gonna try this via the SD card and see how that goes...
Posted: Sat Jun 07, 2014 12:34 pm
What version of the firmware are you running?
Posted: Sun Jun 08, 2014 10:17 pm
by Gr8Scott
I think I'm running 0.80 on the Max when I turn it on. It stops consistently on the same exact spot when I try to run it on the same print. To me, that sort of limits this to a full fledged bug of some sort.
I tried printing it via the SD card alone with the computer turned off and it did exactly the same thing and stopped in exactly the same spot as before.
I have V0.95F on my laptop BTW.
I have the 0.91 version of the firmware I downloaded previously, but didn't install it yet because I didn't want to go through the trouble of re-doing my Config.H. Looks like I need to bite the bullet and get it done to see if that fixes the problem I've been having.
Posted: Mon Jun 09, 2014 12:56 am
Yes 0.8x has a known issue that results in it stopping prints, upgrade to 0.91, just copy the EEPROM settings before upgrading, the SeeMeCNC firmware should be pretty much correct minus the Z-Height and if you have a very early Max, pulley teeth and uStepping.
Posted: Mon Jun 09, 2014 9:21 pm
by Gr8Scott
Polygonhell wrote:Yes 0.8x has a known issue that results in it stopping prints, upgrade to 0.91, just copy the EEPROM settings before upgrading, the SeeMeCNC firmware should be pretty much correct minus the Z-Height and if you have a very early Max, pulley teeth and uStepping.
Excellent advice. I am printing again as I type after following your advice (for the most part). I didn't copy the firmware, but I did go line by line through the entire config.h section copying over all settings that applied from the old version to the new version. Then I saved the results and started printing immediately. I didn't see your advice until just now, but I did more or less what you told me to do LOL. I just did it the hard way LOL.
Z-height seems to have changed a bit since then, so I'll have to set that via EEPROM here in a bit and also make sure the Arduino file matches in case I need to do a further revision later on for some reason. Thus far, the print is looking really good and hasn't stopped at the point that it stopped at before. I'm about halfway through a 6 hour print right now with a 200% feed rate and everything looks pretty good thus far. Slightly blobby, but I expected that. Need to increase retraction just a little bit more and I think I'll be set for this ABS.
