Rostock Max V2 Effector Solid Model
heathenx
Post by heathenx »
Does anyone have a 3D CAD model of the effector for a Rostock Max V2? Right now I'm using PartDaddy's updated effector from repables...the one with 3 fan mounts instead of 1. That model works but I'm not sure if it's pretty much the same thing I have now.
JohnStack
Re: Rostock Max V2 Effector Solid Model
Post by JohnStack »
That's strange, I don't see it in Github....
http://dropc.am/p/KhiI1a
guanu
SeeMeCNC Staff
Post by guanu »
if you are talking about this one http://repables.com/r/294/ then it is currently what we use in all the machine and is the up to date one that we run in the injection molder now... the difference between the 1 fan tab effector and the 3 fan tab is when we took the feedback of walking axles and made the effector thicker, stronger and have a much tighter grip on the axles... so yup, its current
Guanu
Delta Zee Solutions
Post by Delta Zee Solutions »
I'm also looking for a effector plate solid model so I can model up some accessories for the effector plate. I downloaded the Repables STL listed above, but Solidworks doesn't like the large number of faces...
Is there a chance of finding a STEP or parasolid So I can at least interrogate it for some dimensions? STEP would be good.
