Droopy Bridges with PLA Help
Posted: Fri Jun 13, 2014 12:30 pm
Hi guys,
I need some tips for getting better bridging with PLA prints. I have a cylindrical object with a couple of diameter changes in the outside that I am having problems with. The shoulders are about 2mm wide, and when the printer prints the first layer of the overhang, it kind of prints it along the side of the previous layer and it sags and droops randomly making a horrible looking worm of filament where there would be a shoulder.
I've played around with turning on support material, but that resulted in my entire part being encased with a support shell that is stuck to it so tightly I couldn't cut it off (there's probably settings I need to make this less dense) but I would think that there must be something I can do to make this work without support because I have seen some models others have made here that have a lot larger undercuts and they print fine.
One thing I tries was to fillet my overhangs or make them 45 degrees instead of 90. The angled ones came out better, but the layering there looks wavy and blobby, so I think I must need to make some adjustments to get it better. I also tried printing the fan shroud, because it has some bridges, and it was really saggy there too. The ABS fans I did on my first print were better.
Are there any tips or suggestions I can try to improve the undercuts?
Brian
Brian
