Dual Ezstruder Mounts
mlapaglia
Post by mlapaglia »
I am starting to upgrade to a dual extruder. When looking for a way to mount the second ezstruder to the top, I saw on seemecnc's website: http://seemecnc.com/collections/parts-a ... -ezstruder
It says it's for version 1 only, but when i look at the .dxf file on github the two look identical. Is the only reason it won't work with the v2 the top plate only having one cut out for the filament holder? Could I take the .dxf to a CNC and get one cut out to add to my printer, or even make an .stl of it and print it out? ($90 for half a sheet of melamine is a bit steep for me).
mlapaglia
Re: Dual Ezstruder Mounts
Post by mlapaglia »
Took the .dxf file and made the first motor mount:
http://repables.com/r/332
Not sure why the preview is messed up, but if you go to the 3d view you can see it fine. I'll cut the rest up in the next couple of days.
