RJ's v2 Build
Posted: Mon Jun 16, 2014 12:41 pm
by RJLynn67
So far everything is going along swimmingly until I just noticed I installed the Top bottom plate backwards...
SO... since I am quite a bit past this can I continue and just adjust how I assemble the extruder mount? See below
we will see if the image shows up.
Re: RJ's v2 Build
Posted: Mon Jun 16, 2014 1:52 pm
by guanu
yes, actually you built it the way I build them here at the shop... you will just mount the extruder as seen here... https://www.flickr.com/photos/seemecnc/12599516435/ I prefer this way because I like the blinky eyes to look normal when looking at the front of the machine.. but works either way...
Guanu
Re: RJ's v2 Build
Posted: Mon Jun 16, 2014 2:50 pm
by RJLynn67
Just the answer I was looking for! Pressing on!
Re: RJ's v2 Build
Posted: Mon Jun 16, 2014 9:56 pm
by McSlappy
It's totally buggered. You'll need to burn the machine and follow the ritual covered in Appendix B of the manual.
Re: RJ's v2 Build
Posted: Tue Jun 17, 2014 7:18 am
by guanu
McSlappy wrote:It's totally buggered. You'll need to burn the machine and follow the ritual covered in Appendix B of the manual.
SHHHHH thats the members only secret manual for the fifteenth coming of the printer gods who will smite down all who oppose! do not speak of it to the "others"
Guanu
Re: RJ's v2 Build
Posted: Tue Jun 17, 2014 4:54 pm
by RJLynn67
Only software/calibration left! Makes the Ol Form1 look tiny!
Re: RJ's v2 Build
Posted: Wed Jun 18, 2014 6:19 pm
by RJLynn67
Into calibration and everything seems to be working fine.
HOWEVER... When I home the machine it does so nicely. Then I am able to manually move the head in the X and Y directions using the Repetier just fine.
BUT I cannot move the Z Down(Towards the build plate) at all... I can move it up with the up arrow and the Repetier show the Z Axis value changing correctly in Black.
Is it me or is it trying to move backwards, but not during homing?
Re: RJ's v2 Build
Posted: Wed Jun 18, 2014 8:04 pm
by RJLynn67
Well I figured out the error in my ways...
In the Printer Settings under the Printer Shape tab I had the Home Z: dropdown showing Min instead of Max...
Now back to calibrating.
Re: RJ's v2 Build
Posted: Thu Jun 19, 2014 9:46 am
by RJLynn67
Well she is off and printing the PEEK Fan Shroud!
So far so good other than I feel like the manual is intentionally forcing you to work a pause mid print and reload filament as the "2 meters" required to print the Peek Fan Shroud is laughable. There is close to a meter below the extruder :) of course I can see that now. :)
So reloading is not terrible. we will see how it turns out though.
Re: RJ's v2 Build
Posted: Thu Jun 19, 2014 2:22 pm
by RJLynn67
PEEK Fan Shroud Complete
before cleanup: Not too shabby for print number 1 :mrgreen:
Installed it and went to print the Layer Fan Shroud and it would not stick to the surface. Figured two things were against me here. A, I needed to recalibrate the axis after installing it. B, I needed to reapply glue, even though I was printing it in an untouched area.
Fixed both those situations and it is looking pretty nice!
Re: RJ's v2 Build
Posted: Thu Jun 19, 2014 2:46 pm
by nitewatchman
Good looking results!
You might also consider the closed Layer Fan Shroud. I have moved to this design and it puts more air directly where it is needed.
http://forum.seemecnc.com/viewtopic.php?f=35&t=5632
nitewatchman
Re: RJ's v2 Build
Posted: Thu Jun 19, 2014 3:03 pm
by RJLynn67
Of course that looks like a better solution! Dangit! Printing again.... :)
Re: RJ's v2 Build
Posted: Thu Jun 19, 2014 4:07 pm
You'll soon learn that ANY excuse to print something is a good one. :D
Re: RJ's v2 Build
Posted: Thu Jun 19, 2014 4:09 pm
by RJLynn67
Apparently SO! I have been getting quite a few requests from the kids today... :)
