Possible skipped steps
Posted: Wed Jun 18, 2014 3:08 pm
I have checked my belts, cheapskate tension, just replaced steppers with no improvement, and have adjusted stepper driver current to ~1amp (should be more than sufficient for x/y/z). I continue to get what appears to be skipped steps on random prints, but sometimes if the print continues for any length of time it appears to self correct. The offset is typically about 1mm, not much more, sometimes less. Initially I thought there was some issue with the nozzle colliding with warped overhangs, but the issue occasionally happens on parts with perfectly straight walls (cubes, cylinders). I am running conservative speeds (30mm/s, 1200mm/s^2 accel, 35mm/s^3 jerk). I have the TrickLaser arms which I have confirmed have no friction in their joints, my cheapskates fall freely when released. The only issue I can imagine is belt tension. Right now I have the belt tension fairly loose since if I make it any tighter a single tower gets an uneven friction with every rotation of the pulley. I believe the pulley is possibly warped. This symptom was what led me to believe I had bad bearings in a stepper motor when in fact they were fine. When I initially built my machine I had no such issues, I occasionally had the nozzle collide with warped overhangs which resulted in an unsightly print but never any issues like these skipped steps. The fact the issue also occasionally appears on prints with nothing but perfectly vertical walls leads me to believe there are other issues here. I just ordered replacement pulleys as well, hopefully that will help somewhat but I am not extremely hopeful for that solution either. I have checked everything I know to check and continue to get issues. The steppers are new so new crimps and ends on them, no extensions were required. The stepper drivers are DRV8825 drivers (CoolDrv) on RAMPS 1.4 adjusted to 1.1amps per motor, the steppers are Kysan 5.5kg/cm NEMA17, the same thing that was removed except these have flats ground in them. One of my pulleys lost the threads on a setscrew the first time I removed one of the set screws when assembling the kit (they shipped with screws already in, threads galled when removing set screw for first time).
I remember reading about another individual who had a nearly identical issue although much worse here:
http://forum.seemecnc.com/viewtopic.php ... teps#p2730
There was also another thread I read that had a similar problem that had no solution in the thread.
EDIT:
This thread along with graphics most closely describes my problem: http://forum.seemecnc.com/viewtopic.php ... 602#p25594
I typically only get an offset towards the right when facing the front of the machine, though. The right tower (Y?) is also the one with the questionable pulley installed.
Also just realized, I didn't specify that I have a Rostock Max v1.
EDIT:
