intermittent extruder heating
I have a max v 1.1. The extruder is only heating sometimes. Has anyone else hhad this problem
- nitewatchman
Re: intermittent extruder heating
Check you wiring connections. I had the same problem initially and found that the connector on my Modular Power Supply was not firmly plugged in.
nitewatchman
nitewatchman
Connections are firmly attached. Good tip
But still no heat
But still no heat
