Adapting RAMBo connectors for Smoothieboard
Posted: Sun Jun 22, 2014 8:31 pm
by jesse
Anyone know of a source for these connectors?
I need the same Molex SL 2.54 mm type in the photo: 5 qty 4-pin, 3 qty 3-pin, 2 qty 2-pin.
[img]http://i.imgur.com/MqVgK3s.jpg[/img]
mhackney helped me get the name of the connector on IRC:
http://www.mouser.com/catalogviewer/def ... atalog=646
If anyone else is interested, I could order extra to form an upgrade kit for RAMBo to Smoothie adaption.
Re: Adapting RAMBo connectors for Smoothieboard
Posted: Mon Jun 23, 2014 11:12 am
by bdjohns1
You can get them from:
http://www.hansenhobbies.com/products/c ... onnectors/
in reasonable quantities - he sells the board-mount headers as well as the matching connectors for your wiring if you don't already have them.
10 of each of those three sizes will be <$10 + shipping.
Posted: Mon Jun 23, 2014 2:52 pm
by JohnStack
This post is a great reason for double categories. I would have looked for something like this in a Smoothieboard category.
We also need a sourcing category...way too much stuff out there to buy hidden away in threads.
Posted: Mon Jun 23, 2014 6:54 pm
by jesse
bdjohns1 wrote:You can get them from:
Thanks for the link.
Posted: Tue Jun 24, 2014 12:13 am
by bdjohns1
jesse wrote:bdjohns1 wrote:You can get them from:
Tip of the virtual hat to geneb - he links to those guys in the build manual (at least in version 1)
Posted: Fri Jun 27, 2014 4:17 pm
by jesse
Posted: Fri Jun 27, 2014 4:44 pm
Yes, that's it. The stepper color order should be the same. If it turns out to be "upside down" when you test, you change that in the config file.
The end stops are the only potential problem area as you could harm the board. You have it right in your drawing.
Posted: Fri Jun 27, 2014 6:21 pm
by bvandiepenbos
Thanks for the link to the connector source
Posted: Fri Jun 27, 2014 7:32 pm
by jesse
bvandiepenbos wrote:Thanks for the link to the connector source
Delivery took about 2 days, pretty fast.
Posted: Fri Jun 27, 2014 7:55 pm
by bdjohns1
jesse wrote:bvandiepenbos wrote:Thanks for the link to the connector source
Yep, they ship from just down the road from my alma mater of UIUC in Urbana, IL. So, quick delivery for those of us in the Midwest.
Posted: Sat Jun 28, 2014 2:37 am
by Generic Default
Just letting you guys know that any 0.1 inch connectors like that will work. You can use individual ones instead of 2 or 3 or 4 blocks together. I bought a ribbon cable of those little connectors and they work great for Rambo, smoothie, ect. Make sure you have female crimps too!
Posted: Sat Jun 28, 2014 10:05 pm
by jesse
I made the adapters earlier today...
[img]http://s14.postimg.org/a8mm535sd/IMG_5578.jpg[/img]
Once the 3 pin molex pins come in the mail, I'll solder them on to the MAX endstop holes and give it a try.
Posted: Wed Jul 16, 2014 5:16 pm
by jesse
The 3 pin end stop connectors finally arrived from China. Took about a month from Tayda Electronics.
Here's what the board looks like with the adapters:
[img]http://i.imgur.com/5pI7M6l.jpg[/img]
The pins were hot glued against the plastic connectors since they are usually held in place with solder and a PCB.
Here's a decent photo for mapping the pins on the end stops:
http://reprap.org/mediawiki/images/c/c6 ... bottom.png
Posted: Wed Jul 16, 2014 5:22 pm
by jesse
Someone on the #smoothieboard irc chat pointed out that if you get a Smoothieboard without the connectors soldered on, you can just solder the black connectors directly to the board and save some work.
