Cheap Skates, first time adjustments!!
Posted: Tue Jun 24, 2014 12:36 am
Hello,
Okay, if you don't tap down on the T Nuts, or use a nut and washer to set them into the melamine, they will interfere with your first bearing adjustments, and as soon you get brakes on the belt, you'll discover allot of play in the Cheap Skates in the extruded track.
Make sure you tighten down the T-nuts before you make the first time adjustments to the Cheap Skates because, the tape, that holds them down, or if you manage to do what I did, and use the extrusion to hold them in, it will tweak your first adjustments of the Cheap Skates. Make sure the T-nuts are set into the melamine by using a threaded screw and washer on the melamine side. Then, proceed adjusting the Cheap Skate's Bearings.
The T-nuts, were in at different levels, and I couldn't put a finger on why all of my bearings weren't properly seated in the extrusion, and started expecting that the T-nuts might be the problem. I kept adjusting them and finding sticky spots, the bearings riding one side of the extrusion but, not both, and it was common to all three cheap skates, and now I know the real problem, wasn't really a problem at all. So, I spent over a week, and just three days I wasn't working trying to tweak and straighten everything out, to get all seated correctly. The one thing that was touching or rubbing the whole time was the T-nuts. Once, they were all seated, it became possible to make the proper adjustments to the Cheap Skates. But, now, I have to remove the belts, re-adjust the cheap skates, and go back to putting on the belts. It's just a minor malfunction of the Assembly Manual, and not a real problem. Hope you guys spot the oddities before I but, every time you find a better way, mention it here for the sake of others. I started by reading Tip 'n Tricks, went through Fails, and read through problems other people were having well before I started assembling. It's good advice to advise you to do the same.
I just wish, that after all of the trouble I've been through, trying to make adjustments, that at first mention of the T-nuts in the parts list for the assembly of the Cheap Skates, it would be mentioned not to use tape, or just set them in but, use a screw, washer and nylon spacer, to set that T-nut, into the melamine because, the first time you adjust the bearings, the tricks you used with the hot bed, will only work against the first time you adjust the bearings to align with the extrusion. I just believed, it should fit together right, and never set those for three days of working on it, and refused to accept less than correct..
Frankly, I don't think anyone should make my mistakes, if I can see a way around them...
I also used a pop sickle stick as a kickstand for my Cheap Skate because, I didn't have a clothes pin, and didn't need 24, to hold one Cheap Skate. I also found that my really long needle nose pliers, make a really good ramp for the belt, and if stick them clear back to the bottom of the extrusion, then feed belt through, it will guide the belt through the cheap skate, with relative ease. They are spring loaded and try to stay open, and I just let it open up in the grove to catch the belt. Above the T-nut, for bringing the belt down and through, below the T-nut for up and through. The T-nut, is kind of in the way otherwise, and every attempt will seem in vein because, the T-nuts will just block the shot.
James.
James.
