tragedy on a 33hr print... lol
Posted: Tue Jun 24, 2014 1:47 pm
by guanu
damn.. 97% through a 33 hr print.... and we reach the end of the spool.... oh well...
Guanu
Re: tragedy on a 33hr print... lol
Posted: Tue Jun 24, 2014 2:14 pm
by Jimustanguitar
Turn it upside down and that leftover flat at the top will be its base.
Posted: Tue Jun 24, 2014 3:42 pm
by Tinyhead
Quick! Melt the green spool onto the end of the yellow and just have a different colored top!
That does sting though. That's too bad. The print looked really nice!
Posted: Fri Jun 27, 2014 3:39 pm
by TFMike
what is that round black disc on top of the glass?
Posted: Sat Jun 28, 2014 9:27 am
by teoman
How do you mate 2 pieces of filament?
Is there a special process?
Posted: Sat Jun 28, 2014 11:12 am
by barry99705
That's just where you mount the light fixture. Duh! :lol:
Posted: Sat Jun 28, 2014 12:07 pm
by nitewatchman
teoman wrote:How do you mate 2 pieces of filament?
You use a modified Flux Capacitor running at 5 MegaJoules, Any more and it leaves a bulge in the filament.
nitewatchman
Posted: Sat Jun 28, 2014 1:39 pm
by Tinyhead
Just heat up the ends and melt them together. Then take a knife or what have you and shave off the bulge it makes so it's smooth right through.
Posted: Mon Jun 30, 2014 4:57 pm
by teoman
Thank you very much.
So. Could the OP have realized that the filament had finished and added some?
How about a sensor for that?
Posted: Thu Jul 03, 2014 7:32 pm
by Mystichrome
guanu wrote:damn.. 97% through a 33 hr print.... and we reach the end of the spool.... oh well...
Guanu
That sucks, sorry to hear it failed, it was so close. If you don't mind me asking, did you design that or download that design. I'd like to try it myself.
Posted: Mon Jul 07, 2014 12:27 pm
by hagemeyp
How about a micro-switch with a roller mounted on an angle bracket where the filament passes through the hole on the top plate? closed==OK, open==no filament, pause the print. Connect it to X (min) endstop, modify the firmware to PAUSE when the switch is open i.e. no filament.
Hey I've got a few micro-switches lying around, looks like I'll give a prototype a shot.
While at it, I'll add a funnel filament guide, and some sort of pad to clean the filament. What do you think?
Posted: Mon Jul 07, 2014 2:49 pm
hagemeyp wrote:How about a micro-switch with a roller mounted on an angle bracket where the filament passes through the hole on the top plate? closed==OK, open==no filament, pause the print. Connect it to X (min) endstop, modify the firmware to PAUSE when the switch is open i.e. no filament.
There would be a lot of interested parties in your idea of putting the printer in the pause mode if a broken filament is detected.
The electrical connections and the firmware changes to implement would have to be included but I feel it is an excellent idea
that is worth pursuing.
Posted: Mon Jul 07, 2014 9:12 pm
by hagemeyp
Thanks- I am an embedded software engineer and have already done some firmware modes. I'll do a little modeling and see what I can come up with.
Posted: Mon Jul 07, 2014 9:18 pm
by Tinyhead
Please do! I've wanted to do this from the start but couldn't figure out the modifications to make in the firmware.
