TemperatureSwitch Module
Just wanted to let folks know that I contributed a Module to smoothieware: TemperatureSwitch
TemperatureSwitch is an optional module that automatically controls one of the small MOSFETs (through it's Switch) based on a configurable threshold temperature. It is commonly used to turn on/off a cooling fan or water pump to cool a 3D printer extruder hot end's cold zone. Simply, TemperatureSwitch turns on/off the switch.xxx where xxx is the used defined switch type. xxx = fan or misc in the default configuration files.
It is on the most recent edge source and firmware.bin
Cheers,
Michael
[email protected]
Re: TemperatureSwitch Module
Post by [email protected] »
Works great, Thanks for the hard work.
Max 2
xyz DaVinci 1.0 with custom FW for Repetier-Host
Future plans
NextEngine scanner
Droplite or other SLA
Cheers,
Michael
