SeeMeCNC Headquarters Machine Pics
Posted: Sat May 05, 2012 5:25 pm
by PartDaddy
The H-1 with electronics below. Originally how I envisioned it. We'll soon offer this as an upgrade. I still need to make the mounting panel for the Velleman temp boards and switches. Switches to control power to heaters, main power, lights and future accessories.
- H-1 with electronics mounted under. A new kit will soon be available.
- SeeMeCNC Electronic mounting
- SeeMeCNC H-1 with Electronic mounting and prototype heated bed.
There is a heated bed prototype I made weeks ago shown in the picture. Oly & I hope to make test prints this week.
Re: SeeMeCNC Headquarters Machine Pics
Posted: Sat May 05, 2012 5:51 pm
by michaellatif
Looking good. What type of HPB is that? Nichrome wire? Also, any tips on how to level the bed easily?
Posted: Sat May 05, 2012 7:27 pm
by PartDaddy
Hi Michael, I used one 6-32 x 1" flat head phillips in each corner. Instead of messing with springs, I just used only nylon lock nuts. The table is aluminum with RTV hi temp, nichrome wire, and more RTV.
I drilled holes in the stock table.
I jogged the table around slowly with the nozzle nearly touching. Then I used a business card to feel some interference between the nozzle and table. I jogged to sac corner several times and adjusted the table up or down as needed by loosenng or tightening the nylon lock nuts.
If this works, Oly & I will offer a kit.
We also are supporting the printed circuit board concept. I think both are good solutions.
Posted: Mon May 07, 2012 6:40 pm
by Extrude3D
As someone who is looking to buy the H-1 kit, should I wait for this revision.
How long will it take until the new kit is shipped or made?
Posted: Mon May 07, 2012 6:46 pm
by johnoly99
Extrude, Oly from seeme here. We will be selling that stand kit as an option/upgrade, it won't be in the base kit, and our heated bed is prob. going to be a PCB bed that some of the other guys on this site here have been working on. If I were starting a build, I would go for the kit now, and build it/run it/have fun, and when the new stuff came out, pop for that later. Most likely, you will be wanting to play around with nozzle sizes and need parts etc... for mods, so you could order it then too.
Posted: Tue May 08, 2012 8:56 pm
by Extrude3D
johnoly99 wrote:Extrude, Oly from seeme here. We will be selling that stand kit as an option/upgrade, it won't be in the base kit, and our heated bed is prob. going to be a PCB bed that some of the other guys on this site here have been working on. If I were starting a build, I would go for the kit now, and build it/run it/have fun, and when the new stuff came out, pop for that later. Most likely, you will be wanting to play around with nozzle sizes and need parts etc... for mods, so you could order it then too.
Okay, sounds good. I shot you guys an email too.
