Success! (kind of)
Posted: Mon Jul 14, 2014 2:06 pm
Well thanks to all of the help from the forum my build is complete. I went with the screw-in thermistor and heater cartridge and a big thanks to f15sim for the great Youtube video. I have a couple of problems that I was looking for some guidance on.
Heat bed slowness
So after searching around on the forums it seems like it is a common issue for the heat bed to take a long time to get to 90C. For me I sat there for like 30 waiting and it still didn't quite get there. I ended up covering the bed with paper towels to get it to fully heat. How can I speed this up? If I run 3 wires for each terminal instead of 1 will that do the trick?
The first print
I downloaded the STL files for the fan shroud but when I started the print it printed the first layer in mid-air, slightly above the print bed. This caused filament to build up on the nozzle and thus it screwed up. I did configure the end-stop screws like it described in the manual. Any ideas? Also, when the nozzle reaches 225C a small amount of filament seems to be constantly coming out of the nozzle. Is this normal?
Thanks again for all the help!
Lee
Heat bed slowness
The first print
Lee
