No heat to bed or extruder.
Posted: Tue Jul 22, 2014 7:03 am
I just finished assembly of my V2 Max last night {Yayyy, but I'm not posting to brag}
I seem to have one of the first V6 Onyx and I have wired everything up as shown in the manual.
Same/similar to V5, LED across the Heat 0 connections on Rambo board, etc.
At power on there was a blank LCD screen, which after MUCH checking of wires and cables turned out to be the contrast pot on the back of the board needing a twiddle.
Arduino EEPROM firmware load and repetier host install all went fine, it goes to home, manual controls in repetier host all work, it even "dry run" pretends to print the peek fan shroud that I downloaded.
There is NO HEAT to the bed, repetier shows whatever target temp I set as a goal, but it never moves from room temp.
The thermistor works - if I Hold my hand on the onyx for 10 seconds or so repetier host shows the temperature climbing.
Same thing on the extruder, though I am less concerned about that for the moment since I am doing dry runs without filament.
The 12 volts on all the black/yellow pairs of the power connector to the Rambo are all good.
There is no voltage on HEAT 0 or on HEAT 2 - i.e. the Rambo just isn't putting out.
The red LED on the RAMBO board does light when I turn on the heat bed fan via manual control in repetier host.
I should mention that I haven't connected fans yet, since I haven't printed fan shrouds - I don't THINK this should matter, but as it is the only "incomplete" in my build I mentioned it.
