zeroing bed
Posted: Thu Jul 31, 2014 6:22 pm
by Behold
This may have been discussed but when I searched the issues didnt seem the same as what is happening with mine.
I have a Rostock Max ver 1.
My hot end became loose from the ceramic sheath and I replaced it with a new hot end.
The new hot end is a different length than the old one.
How do I adjust for the added length?
Re: zeroing bed
Posted: Thu Jul 31, 2014 6:25 pm
by Behold
by the way if i start a print it slams into the glass... scary!
Normally use mattercontrol but have been trying to communicate through repetier to no avail
Re: zeroing bed
Posted: Thu Jul 31, 2014 6:26 pm
I believe it's covered in the manual, which is available for download.
Basically you need to adjust the X Y and Z max length settings in the EEPROM settings, I think the latest repetier has a quick way to do it from the LCD, but I don't use it.
Re: zeroing bed
Posted: Fri Aug 01, 2014 9:48 am
by Behold
yes, i found that part of it however i cannot connect with repetier. it says its connected but no manual controls or gcode commands respond
Re: zeroing bed
Posted: Fri Aug 01, 2014 9:56 am
by Jimustanguitar
Check your com port in device manager.
If that doesn't work, see if you can connect with Arduino IDE and re-flash it.
Re: zeroing bed
Posted: Fri Aug 01, 2014 11:31 am
by Behold
The comport is correct since it is the same in mattercontrol and I am able to control and print from mattercontrol
Currently its COM3
Re: zeroing bed
by Behold
Love your avatar!
Re: zeroing bed
Posted: Fri Aug 01, 2014 11:34 am
If the com port is correct than the baud rate setting in Repetier Host must be incorrect.
The baud rate has to match what is in the Repetier Firmware.
Re: zeroing bed
Posted: Fri Aug 01, 2014 11:55 am
by Behold
adjusted the baud rate to 128000 and was able to connect
