Stripped Timing Pulley Screw - Better metal?
Posted: Sun Aug 10, 2014 12:30 pm
by jeffhuber
I stripped the screw on the timing pulley today as I was taking it apart to reapply some threadlocker and tighten stuff down. I was getting some spin on all three of my axes. The metal on the screw seems to be pretty soft. Does anyone know what kind of metal it is and if it is possible to use something more durable? For instance - would stainless steel be more durable?
I went ahead and just ordered a new pack http://seemecnc.com/collections/parts-a ... ley-3-pack - i figured this would probably happen again.
Jeff
Re: Stripped Timing Pulley Screw - Better metal?
Posted: Sun Aug 10, 2014 12:39 pm
If you replace the screw with something stronger, next time you strip the thread on the pulley.
You don't need all 3 screws in there, especially with the newer motors that have flats on the shafts.
Posted: Sun Aug 10, 2014 12:53 pm
by Gr8Scott
My pulley centers appear to be cast aluminum. You can only tighten it so much before the aluminum gives way. If you haven't ground nice flats on your motors, you need to do so before re-installing the new pulleys. Also make certain you are using good relatively fresh thread locker. That stuff goes bad over time. I used old thread locker on my pulley screws and it essentially turned into grease, which exacerbated the problem for me.
Posted: Mon Aug 11, 2014 10:31 am
by jeffhuber
Gotcha. thanks guys! I guess I will just hope for better luck this next time
Posted: Tue Aug 12, 2014 11:53 pm
by Gr8Scott
jeffhuber wrote:Gotcha. thanks guys! I guess I will just hope for better luck this next time
Let us know how it turns out. We're here to help if you need us.
