Solved:Calibration..Arms (travel) hitting the towers!
Posted: Sun Aug 10, 2014 5:11 pm
Hi, I am so close to completing my calibration and all the sudden,...when I run one of the calibration commands to check the x,y,z tolerances, the hot-end assembly travels all the way to the towers and makes contact with the them. It was just working fine before and this started happening! Any ideas where to look for a fault?
UPDATE: After looking at the log, I am seeing Warning:Invalid dataCoordinate- Move ignored.
Also: ERROR: No movement in Delta segment with >1 segment. This should never happen and may cause a problem!
Update2: I reinstalled the Reptier drivers and that fixed it! Somehow there must have been a software corruption that was causing the errors.
Got it going now!
Thanks,
Glenn
Got it going now!
Thanks,
Glenn
