				Parts to convert the Orion to Rostock ish size.
				Posted: Tue Aug 12, 2014 1:15 am
				by PopolZ
				So I'm getting a bit limited by the size of the Orion. I was tempted to order a second printer but I'll keep my wallet happy and convert the Orion instead.
The parts list I need to order: the Rostock delta arms, laser cut sheets, glass plate, Onyx bed, 3x 48" of 1X1 T slot and GT2 belts.
I know I'll have to rewire a few things with longer wires.
Am I missing anything???
				Re: Parts to convert the Orion to Rostock ish size.
				Posted: Tue Aug 12, 2014 8:44 am
				by Holy1
				I considered this also,  it should work fine. However I considered the costs and time involved. You would have useless parts left over from the Orion in a box and a larger max.  I decided to just to buy a new max.  The build time would probably be comparable and much cleaner and I will have two printers. You can always sell the Orion too.
				Posted: Tue Aug 12, 2014 8:47 am
				The V2 conversion kit would have most of what you need. I don't have the parts list in front of me, but I know it would get you awful close.
Have to order the larger Onyx bed at least.
				Posted: Tue Aug 12, 2014 11:39 pm
				by PopolZ
				The V2 conversion has quite a few parts I already have.
				Posted: Fri Aug 15, 2014 8:38 pm
				by Fester
				I will order the Max v2 soon
       2 printers.... Yeeee haaaa  the only way to melt more plastic ...
 Now I just have to sell a few Rc planes ...
				Posted: Sat Aug 16, 2014 4:23 pm
				by PopolZ
				Well my printer upgrade money just went away in a lathe/mill combo machine
it's a bigger toy
				Posted: Mon Aug 18, 2014 9:28 am
				PopolZ wrote:Well my printer upgrade money just went away in a lathe/mill combo machine
it's a bigger toy
That's next on my list. I'm thinking about a combo machine from Grizzly and then converting it to CNC with my recently acquired knowledge of it from 3D printing.
				Posted: Mon Aug 18, 2014 10:46 am
				by PopolZ
				Jimustanguitar wrote:PopolZ wrote:Well my printer upgrade money just went away in a lathe/mill combo machine
it's a bigger toy
It ain't as easy as 3D printing. When you get to depth of cut, feed rate, rpm, width of cut, plunge rate, end mill changes + most likely a few things i'm forgetting are the difference between a succesful cut or a mill breaking and shooting across the room.
edit: oh and it's messy!
				Posted: Mon Aug 18, 2014 11:14 am
				Correct you are. I'm semi-familiar with the intricacies of "real" machine work, and definitely understand that it's no walk in the park to automate, I just meant that I'm not scared of stepper motors and controller boards anymore. I'd probably start with something simple like auto-feed, and keep going from there.
				Posted: Mon Aug 18, 2014 11:40 am
				by PopolZ
				Once your have you machine running and fully calibrated comes the fun part of getting a good cam software.
So much to choose from and so damn expensive
				Posted: Mon Aug 18, 2014 12:21 pm
				by Mac The Knife
				For the hobyy work I do with my small mill, (Sieg X2)  I use Mach 3 to control it, and the cam software I use is Sheetcam, Meshcam and V-Carve. To simulate toolpaths, I bought Cutviewer Mill with Meshcam.
				Posted: Mon Aug 18, 2014 1:15 pm
				by PopolZ
				I also bought Meshcam and Cutviewer but they have big downsides when it comes to the 4th axis.
				Posted: Mon Aug 18, 2014 2:26 pm
				Sorry for jacking your thread, OP
				Posted: Mon Aug 18, 2014 3:18 pm
				by PopolZ
				It was my thread anyways... even if we're off-topic it's still interesting!
The new beast in its crate...
[img]
http://popolz.net/temp/IMG_20140818_141252.jpg[/img]
