part fan
Posted: Wed Aug 13, 2014 7:45 am
by p38nut
I am trying to finish up my Max. I downloaded the part layer fan zip file but when I go to open it, zip says its an invalid file. Where can I get this file from instead? I have downloaded other layer fans, but the mounting tabs are too far apart.
Thanks. Mike
Re: part fan
Posted: Wed Aug 13, 2014 7:52 am
by guanu
here's the stl of my latest revision
Guanu
Re: part fan
Posted: Wed Aug 13, 2014 9:05 am
by p38nut
Thank you. I will print out this tonight.
Re: part fan
Posted: Wed Aug 13, 2014 8:38 pm
by PhoenixNZ
I encountered the same problem where the file was just a random string of alphanumeric gibberish. I just renamed the part to fan_shroud.stl manually and it worked fine from there
Judging by comments on the download page this has happened to others.
Maybe SeeMeCNC or whoever manages the download page can re-upload the file.
Re: part fan
Posted: Wed Aug 13, 2014 8:43 pm
by McSlappy
Are you using a mac or do you have file extensions turned off? Seems like your OS is forgetting that it's an .stl for some reason...
Re: part fan
Posted: Thu Aug 14, 2014 9:19 am
by p38nut
guanu wrote:here's the stl of my latest revision
Guanu
This part printed out great for me. Just what I needed. Thanks again. Mike
Re: part fan
Posted: Thu Aug 14, 2014 9:52 am
by guanu
glad to hear it!
Guanu
Re: part fan
Posted: Thu Aug 14, 2014 12:09 pm
by PopolZ
Guanu
I was about to draw my own. Printed and installed it last night.
Trying it now and it's helping quite a bit with the stringing.
Re: part fan
Posted: Thu Aug 14, 2014 10:25 pm
by PhoenixNZ
McSlappy wrote:Are you using a mac or do you have file extensions turned off? Seems like your OS is forgetting that it's an .stl for some reason...
Naw, I had the same problem with Windows. Windows just calls it a "file" and it doesn't have an extension - it's just a string of alphanumeric characters that the computer can't recognise.
Editting the name to "xxxx.stl" works in fixing the problem.
