Orion Repair Manual
Posted: Thu Aug 14, 2014 9:18 pm
by Hank106
Is there a manual available for typical repairs the Orion requires? Even just an assembly manual would be helpful for disassembling to fix something.
Re: Orion Repair Manual
Posted: Thu Nov 27, 2014 12:07 pm
Hank106 wrote:Is there a manual available for typical repairs the Orion requires? Even just an assembly manual would be helpful for disassembling to fix something.
There is the Orion Users Manual V2 located here:
http://forum.seemecnc.com/viewtopic.php?f=65&t=4186
Posted: Thu Nov 27, 2014 1:04 pm
That's the user's manual Eagle, not an assembly manual.
Posted: Thu Nov 27, 2014 2:26 pm
geneb wrote:That's the user's manual Eagle, not an assembly manual.
Thank you, now fixed.
Posted: Tue Jan 03, 2017 6:58 pm
by rurwin
Since there isn't a repair manual, would it be possible to put together a post describing the differences between the Orion and the Max V3? It doesn't need excruciating detail, just notes on how they are similar and different. They both use Rambos, but are the extruder and the hot-end the same? If not, what are they called so we can look up the specs and details ourselves. That sort of thing.
Posted: Wed Jan 04, 2017 2:01 am
by Jimustanguitar
They'll both have the same control board, steppers, extruder, carriages, etc. The main difference right now (aside from the build volume), and one that I'm sure will be updated soon, is the accelerometer board and the new hotend. An Orion today does not have those parts, as far as I know. Aside from the HE280 assembly, they're pretty much the same machine in two different sizes. There are some assembly and cosmetic differences, but they have almost identical component and feature lists.
Posted: Wed Jan 04, 2017 2:28 am
by rurwin
Thanks. That's exactly what I wanted.
