Rostock Max2 only runs 3-5 minutes then stops
Posted: Mon Aug 18, 2014 3:32 pm
by Kevinvandeusen
I have tried several models, all the same result. this is happening on the sd card, does not seem to happen over usb. I will have to go back and try a pc connection, I took it to my store, and my laptop is at home. any other ideas?
Re: Rostock Max2 only runs 3-5 minutes then stops
Posted: Mon Aug 18, 2014 8:26 pm
Kevinvandeusen wrote:I have tried several models, all the same result. this is happening on the sd card, does not seem to happen over usb. I will have to go back and try a pc connection, I took it to my store, and my laptop is at home. any other ideas?
Have you tried a different SD card?
Posted: Tue Aug 19, 2014 8:35 am
Eagle makes a great point. Sometimes there are SD hiccups that plague specific cards. Use at least a class 4 card, and try again
The lights are staying on, right? It's not power related, it truly is just a mysterious pause in the print?
Posted: Tue Aug 19, 2014 9:56 am
by Kevinvandeusen
yes it is a mysterious pause, used a different card, and it works!! THANKS!!!! btw, the offender was not a class 4
Posted: Tue Aug 19, 2014 11:10 am
Kevinvandeusen wrote:yes it is a mysterious pause, used a different card, and it works!! THANKS!!!! btw, the offender was not a class 4
I'm glad that the new card fixed it for you. I had the same problem with the same solution.
Posted: Tue Aug 19, 2014 3:04 pm
by Kevinvandeusen
yes, it is strange bcuz same card works well on my flashforgei! Eagle, going to Seattle?
Posted: Tue Aug 19, 2014 4:04 pm
Kevinvandeusen wrote:yes, it is strange bcuz same card works well on my flashforgei! Eagle, going to Seattle?
No, can't make it to Seattle.
