Final Layers print problem
Posted: Sat Aug 23, 2014 5:23 pm
by bolive
I am using an Orion And when i get to the last few layers that are small they are deformed. Here are some pictures of the problem. It almost seems like there isn't enough time between printing one layer and the next.
Pictures of the prints
https://dl.dropboxusercontent.com/u/906 ... G_4515.JPG
https://dl.dropboxusercontent.com/u/906 ... G_4517.JPG
Picture of the Repetier-Host Screen
https://dl.dropboxusercontent.com/u/906 ... roblem.jpg
Thanks
Re: Final Layers print problem
Posted: Sat Aug 23, 2014 6:39 pm
by DavidF
do you have a cooling fan on the print? Try slowing the print speed down on the last feew layers....
Posted: Sat Aug 23, 2014 6:46 pm
by bolive
Thanks I will watch and see if the fan turns on
Posted: Sat Aug 23, 2014 8:01 pm
by bolive
Fan didn't turn on. Do you know what setting i would need to change in slic3r to turn it on?
Posted: Sat Aug 23, 2014 9:26 pm
by Mac The Knife
When you open slic3r config, click on the filament settings tab. Here you will find the cooling options. I have mine set for automatic, and the threshold is set for 15 seconds or less per layer. I also have it set to sloow down the print speed at 10 seconds per layer.
Posted: Sat Aug 23, 2014 9:52 pm
by bolive
ok thanks
Posted: Sat Aug 23, 2014 9:55 pm
by Holy1
The part also looks quite small. It may help to print another object beside so the plastic has longer to cool.
Posted: Sun Aug 24, 2014 4:28 pm
by bolive
thanks
