I finished the max v2 build layer separation problem
Posted: Mon Aug 25, 2014 4:56 am
by duvdev
Hello.
I just finished the build and the calibration. On the first
Print of the fan holder it started up good and after about 1 cm I saw layer separation. The hot end was at 230 seg and the bed at 90.
Al the part went out distorted.
Also I noticed that the extruder motor slip on the abs filament and "eats" it.
Can you please advise what to do?
Thanks
Re: I finished the max v2 build layer separation problem
Posted: Mon Aug 25, 2014 1:02 pm
by gestalt73
hey duvdev,
sounds to me like you're not printing hot enough. 230c should be hot enough to print ABS, but depends on a couple of things, including print speed.
I think the stock hot end is good to 240c, so you could try raising the temperature, or maybe slowing the print down a bit.
What are your print speeds?
Posted: Mon Aug 25, 2014 1:10 pm
Have you verified the Hotend temperature with a thermocouple?
Layer separation is usually a function of not printing hot enough for a strong layer bond.
