Extruder jamming? Consider greasing the spool support
Posted: Thu Aug 28, 2014 8:42 pm
This is pretty simple: My Orion's extruder was skipping/kicking back. The hot end might be a little jammed, not 100% sure, but the problem seemed to come and go. I seemed to get it mostly on the 1 kg filament spools that I got from SeeMeCNC, but not on the very small spools I had left over from a previous printer.
Then I realized that it stopped skipping when I pulled a bunch of filament off of the spool ahead of time. But then when that slack was used up, it started skipping again.
I think there's a fair amount of friction between the heavy spool and the spool support. So, I greased it. Haven't heard a skip since.
So there you go. Something to consider if your cold end is having trouble.
