Blown surface mount fuse
Posted: Sun Aug 31, 2014 10:21 am
by bgovoni
Hey Guys, recently purchased the rostock v2, upon completing everything worked well. I was able to calibrate it, print the fan shroud, then while attempting another calibration to get things just perfect. As soon as I turned on the extruder. I heard a pop and now nothing but fan noise. I can't communicate with it nor see it arduino for a reflash. This fuse fails a continuity test with a multimeter so I assume thats my problem.
Do you know the part number of this fuse and place that ships quickly? This is killing me being 98.9% done...
Also, any thoughts for the pop? I had a hell of a time crimping the end for the temp sensor on the hot end down by the rambo. I suspect I may have shorted down there since my crimps were too big to fit in the plastic. Everything else on the install was flawless.
http://imgur.com/l5rS5SK
Re: Blown surface mount fuse
Posted: Sun Aug 31, 2014 11:32 am
You'll want to check the Hotend wiring before you replace the fuse.
Fuse numbers are here
http://forum.seemecnc.com/viewtopic.php ... fuse#p4209
