Solid model of effector
Hansen
Post by Hansen »
Hi all
Does anybody happen to have a solid model (STEP file f.ex.) of the RMv2 effector found here: http://repables.com/r/294/
Thanks
Hansen
heathenx
Re: Solid model of effector
Post by heathenx »
Yes, I have one that I can send you. I think mine was converted to a solid model from the stl.
Hansen
Post by Hansen »
Great :-) can you attach it here or do you need an email address?
heathenx
Post by heathenx »
Sure.
70832 platform.zip
(277.56 KiB) Downloaded 361 times
Hansen
Post by Hansen »
oh... my... god... This thing is perfect. If you only knew how much time I and three CAD people (apparently with the wrong tools and/or lack of skills) have spend trying to do what you did...
So... You really (really really) need to tell how you do it? What tools do you use? Or did you convert this into a solid by hand?
Thanks again!
- Hansen
heathenx
Post by heathenx »
Well, I don't quite remember what I did. It was so long ago. I think I might have brought the stl into Autodesk 3DS Max Design and exported as a sat file. That of course opens just fine in Autodesk Inventor. That's how I usually convert stl's anyway. The free Autodesk Fusion 360 used to convert stls to solids wonderfully but something changed a few releases ago. I haven't tried with the latest update (that I just installed today). Perhaps it works again. Besides that I have some other ninja-fu that I can use. Where there is a will there is a way. ;)
Hansen
Post by Hansen »
heathenx wrote:The free Autodesk Fusion 360 used to convert stls to solids wonderfully but something changed a few releases ago.
I think I know what happened to it... it is no longer free ;) and I have yet to find a good way to convert these STLs... mmm... thinking...
heathenx
Post by heathenx »
Autodesk Fusion 360 is still free for personal use.
