Lots of Print Problems
Posted: Thu Sep 04, 2014 9:27 am
Hello,
I finally thought I had my Rostock Max V2 working well but after trying a larger print I am having a bunch of problems.
1. This is a print where the part was oriented vertically, since the finished part is 10 inches long. I canceled the print after the first two inches because it was already very wrong. There are two main problems. One the print seems to be shifting as the printer gets higher. It seems to drift to the right. Two I am seeing this in all my prints where the print seems to be stretched vertically. The circle becomes an oval.
[img]http://i.imgur.com/x9aTakFl.jpg[/img]
http://i.imgur.com/x9aTakF.jpg
[img]http://i.imgur.com/cWqdMEPl.jpg[/img]
http://i.imgur.com/cWqdMEP.jpg
[img]http://i.imgur.com/wEHqrpil.jpg[/img]
http://i.imgur.com/wEHqrpi.jpg
Here you can see how the circle has been stretched. The lower black line is the width of the circle and the top black line is the height.
[img]http://i.imgur.com/eFMYhGtl.jpg[/img]
http://i.imgur.com/eFMYhGt.jpg
After failing to print the model vertically I split it into two parts so I could print it laying down. Then I had even more problems as seen below. In the top left corner and the right side no filament is being extruded. It also seems like the extruder is slipping a lot. I lightly grabbed the filament as it was printing so I could feel the filament moving and it seems to move for a bit then stop even though the white gear on the extruder is still rotating. Has anyone else had problems with the filament slipping or does my problem lie elsewhere?
[img]http://i.imgur.com/g34TIiil.jpg[/img]
http://i.imgur.com/g34TIii.jpg
[img]http://i.imgur.com/Kj7Kn8bl.jpg[/img]
http://i.imgur.com/Kj7Kn8b.jpg
Thanks for any help you can offer!
