1:turn on printer
2:fire up fire up software on pc (sorry for the vagueness but i cant remember the name of the software we were originally using but it should be noted that the same results were seen when using matter control)
3:connect to printer (from within software on pc)
4:issue a G-code to printer (i usually used G28 (home) for testing purposes but did try a few others as well with more or less the same results)
5:printer starts doing the harlem shake(all motors have a strange jitteryness to their movements unlike the smooth movement seen during earlier calibration steps, and one or more motors are going the wrong direction. number,speed and direction of motors changes with every reset)
6:scramble for power switch
7:reflash stock firmware, reset values to their original statuses and reupload the now "de-modified" firmware, repeatedly place forehead firmly against wall at high speed, check stepper motor connections even though they worked just fine prior to firmware modification, try shifting all 3 axis steppers left or right, check motor wiring again, tinker with firmware some more, repeat the forehead/wall thing, get advised by someone on irc to check motor wires again, go into cursing fit while checking motor wires (by the way, the wires were exactly as they were the last time i had looked at them. surprising eh?),
8:get extremely frustrated and leave printer alone for several months (work, life, etc)
9:roommate decides its time that the very expensive and unwieldy paperweight fulfill its destiny of making lots of plastic knick knacks
10:i come to thee, oh great knowers of things in search for thine assistance in this great quest
at this point im totally lost on how to proceed. as stated i know the steppers are wired right, i know that flashing a stock firmware doesnt fix it and in fact im not even entirely sure that the flash is taking. any ideas? at all? that dont involve checking the darned stepper wiring again?
