Source for 4mm Quick Connect PTC Fittings...
netdefilr
Post by netdefilr »
I had an issue with a clog in my bowden tube. Well after trying to fix the issue, I need a PTC fitting replacement. Seemecnc is sold out.
But I'm not coming up with an exact replacement. Can someone more savvy with buying these parts steer me in the right direction?
bubbasnow
Re: Source for 4mm Quick Connect PTC Fittings...
Post by bubbasnow »
Generic Default
Post by Generic Default »
I'm not 100% sure about this, but it may make sense to buy one that's rated for a higher pressure. These things are notorious for breaking and it makes logical sense to me that a higher pressure unit would be stronger and more durable. The amazon ones are only rated at 145 PSI.
I bought a bunch for experimenting with a few days ago from McMaster.
http://www.mcmaster.com/#push-to-connec ... gs/=tq8j5r
Check out the Tri hotend!
McSlappy
Post by McSlappy »
I found some here locally (not that the source helps you) and I mention it only because they have zero play when connected with my bowden while the stock ones have a tiny amount of play.
netdefilr
Post by netdefilr »
Generic Default wrote:I'm not 100% sure about this, but it may make sense to buy one that's rated for a higher pressure. These things are notorious for breaking and it makes logical sense to me that a higher pressure unit would be stronger and more durable. The amazon ones are only rated at 145 PSI.
When I go to the link it's to these types of parts in general. Do you know what to click on or have a more specific link to the correct part?
McSlappy wrote:I found some here locally (not that the source helps you) and I mention it only because they have zero play when connected with my bowden while the stock ones have a tiny amount of play.
You have to find out what those are. Zero slop is the bowden tube holy grail.
jesse
Post by jesse »
netdefilr
Post by netdefilr »
jesse wrote:10 for $7.26
http://www.ebay.com/itm/321063745830
Any USA source? Could take forever from Hong Kong.
jesse
Post by jesse »
SeeMeCNC sells them: http://seemecnc.com/collections/parts-a ... tc-fitting
Post by Mac The Knife »
You obviously didn't read the first post. :)
netdefilr
Post by netdefilr »
Turns out they got them back in stock this morning. Thanks for the help guys.
