Extruder motor problem
ericpudding
Post by ericpudding »
Whenever I'm printing something the extruder motor keeps randomly quickly jumping backwards and loud cracking like noises happen. Not really sure why this is happening because the problem occurred mid print when I increase the speed multiplier on the lcd screen.
Holy1
Re: Extruder motor problem
Post by Holy1 »
The hotend is not hot enough. The noise is caused by the hobbed gear skipping on the filament. Try increasing the hotend 5-10 degrees.
DavidF
Post by DavidF »
The extruder is basically slipping from high resistance of filament feed. If you are increasing the speed, you might want to up the temp as well.
A clogged nozzle can cause the extruder to slip as well.
Lost pla castings? see me
teoman
Post by teoman »
Is the print normal?
It is supposed to retract on occasion.
ericpudding
It was jerking on points when it was suppose to retract. What settings for speed and temperature do you guys use in Repetier for PLA?
