Printer Shifting by half a cm around the 50th layer
Posted: Sat Sep 20, 2014 8:46 pm
by Squals6
Hey everyone, My Orion Delta started randomly doing something really random a few days ago, every print now, it shifts about half a cm around the 10-20th or so layer, ruining the prints. The prints themselfs arn't moving as the base is still air tight to the printing bed. anyone have any ideas?
I have a feeling it might be the filament chord getting stuck at some point during the print, holding the extruder back and then the printer trying to finish the job but not at 0.0 anymore, anyone have any way of keeping the wire up, i find it's constantly getting in the way when I home the extruder, very annoying.
[img]
http://i.imgur.com/yHvhQYTl.jpg[/img]
[img]
http://i.imgur.com/Hd0M2tSl.jpg[/img]
[img]
http://i.imgur.com/IZyyeGnl.jpg[/img]
Re: Printer Shifting by half a cm around the 50th layer
Posted: Sat Sep 20, 2014 9:05 pm
by teoman
It seems to be directly opposed to a tower. Looks like the X tower.
move the end effector around and and see if that is the problem. If it is getting stuck it is either making the stepper motor skip or the belt slip.
I would fondle the wire bundle going to the hot end, maybe push it up a bit.
Posted: Sat Sep 20, 2014 9:08 pm
by Mac The Knife
Also check the pulley on the stepper motor, the set screw may have come loose.
Posted: Tue Sep 23, 2014 3:35 pm
by Squals6
Hey thanks for the info guys! I actually added a small Lift to the print job and played with the retraction settings and it is working fine now. It must of been getting stuck on something cause the prints have been great since. Thanks still! very cool of you guys to help
Posted: Wed Sep 24, 2014 7:20 am
by teoman
Do you mean that the nozzle hits your print and moves the print?
OR your nozzle is hitting the print, and then one of the problmes described happens (or unknown problem)
and not hitting the print solved it?
Posted: Sat Nov 08, 2014 12:03 am
by mlapaglia
If you're using Cura, make sure you don't have any malfunctioning plugins. I had one that after 5cm height was moving the nozzle off the bed. Took me way too long to figure out what was happening.
Posted: Wed Jan 07, 2015 8:14 pm
by vijayh
I just recently assembled my Rostock Max v2 and I'm having the same issue. In fact my prints look very similar to the third photo posted. It seems the nozzle is bumping against layers of the print and then the extruder becomes offset. Squals6 fixed the problem by "adding a small lift to the print job and playing with the retraction settings". Can someone tell my how to do that? I'm using MatterControl and don't see any option to adjust the Z-lift or retraction. Thanks.
Posted: Wed Jan 07, 2015 11:08 pm
by Tonkabot
Maybe your over-extruding, which I have had make the print hang up on the nozzle.
