Can anyone slice the 3 Heart Gears or 3 Cube Gears?
Delta Zee Solutions
Post by Delta Zee Solutions »
I've been trying to come up with a neat gadget print as a handout to clients and friends to show off the R Max's capability. (I'm open to suggestions).
I like Emmet's heart and cube gears as well as his transmission, but I have yet to be able to slice them with Slic3r. His STL files all seem to come in with problems ( not manifold error). Even after trying Netfabb repairs, I still get the same errors. If I allow Slic3r to slice anyway, some of the bodies disappear but the holes are sliced.
Kisslicer seems to slice it OK but I'm having different problems with running it's G-code...namely the extruder retracts the set 4mm, but does not return the 4mm to continued extruding. :x Like I said, that's a different issue.
I was wondering if anyone else could try his files and see how well they come into Repetier and Slic3r?
Emmet's heart files: http://www.thingiverse.com/thing:243278
Emmet's cube files: http://www.thingiverse.com/thing:213946
Emmet's transmission files: http://www.thingiverse.com/thing:34778 I haven't tried this on yet.
I sure would like to know it's the files and not me. The comments on Thingiverse all say they have no problems.
TIA,
Mark
bubbasnow
Re: Can anyone slice the 3 Heart Gears or 3 Cube Gears?
Post by bubbasnow »
ive sliced these with kiss and s3d no issues
Delta Zee Solutions
that sure was a quick reply!
So have you recently done it? I know he's updated his files....
If they open OK for you, What am I doing wrong? A lot of my other downloads from Thingiverse have been fine.
Could it be a corruption in my software? I'm running Repetier v1.0.1 and Slic3r 1.1.7
Thanks
bubbasnow
Post by bubbasnow »
yea i did the heart gears 5-6 for my wife this year.
Delta Zee Solutions
bubbasnow, would you be willing to download the heart 5-6 and try it with Slic3r?
Delta Zee Solutions
Not sure what happened, but I updated Repetier to 1.0.5, loaded the original STL and after 5+ minutes it sliced OK.
I wasn't expecting a 20 hour pring with a 50% in ilfil and no support....
I'll post pics (much) later tomorrow.
Thanks
