WHY skirt smaller than object
Posted: Wed Oct 15, 2014 11:23 pm
by ahgu
I just installed reptier 1.05.
the object I try to print, I looked the g-code layer.
the skirt layer is smaller than the object, why is that?
I attached the STL file as well.
gudingjiaju.stl
(248.13 KiB) Downloaded 484 times
Re: WHY skirt smaller than object
Posted: Thu Oct 16, 2014 9:42 am
by Jimustanguitar
Because.... derp.
That doesn't seem right. Have you tried slicing it with something else to try and determine if it's the model or the slicer?
Posted: Thu Oct 16, 2014 12:22 pm
by Mac The Knife
It loaded and sliced fine for me. However, I was able to duplicate your problem by setting the brim distance to a negative value,.
Posted: Mon Oct 20, 2014 10:13 pm
by ahgu
You using same version?
Posted: Tue Oct 21, 2014 8:20 pm
by Mac The Knife
The first time, I used an earlier version. Tonight, I used the same version of Repetier, and the latest version of Slic3r, and other then seeming to take longer, it still sliced fine.
Posted: Mon Dec 08, 2014 12:08 pm
by lroger01
I know this is an older post, but I think I know what is happening. In Repetier or Mattercontrol, check and see what the first layer slice looks like. The brim layout is based on the first layer. If the bottom of your model isn't flat, the brim will circle what will print on that layer.
Posted: Mon Dec 08, 2014 3:20 pm
by PartDaddy
I've set the skirt layer negative distance and let the first layer print over it. I don't do this regularly. I was printing multiple copies of something. A delay at the end to cool the bed, then some gcode to knock the part off the table. Next, I copy & paste multiple copies of everything, saved to SD card and let it rip!
