Custom G-code digital pin control
Posted: Thu Oct 23, 2014 1:34 pm
Hey all,
Does anyone know of a method that I could use to control an arbitrary digital pin on my azteeg x3 pro through a g-code function?
I have been doing a lot of experimenting with my kraken quad extruder and multi extruder printing. One thing that I have noticed with multi extrusion is that the hot ends take significantly more time to cool down to a temperature where oozing is not an issue then they do to heat up. With this in mind, I want to have a fan specifically placed and with air routed specifically to cool the heater blocks down durring an extruder change. The idea is that I would have a g-code reference to that fan so that I could control it though the slicers extruder change g-code. Does anyone know of a method that I could use to control an arbitrary digital pin in this fashion? I would like to keep this separate from my layer cooling fan (although I don't even have one currently) as I may want this feature in the future.
Thanks
Mike
Thanks
Mike
