Blower Mount STL Files
Posted: Sun Oct 26, 2014 9:45 am
by RocketMagnet
I'm looking to print out a replacement blower mount with a tiny mod. However the Stock blower on my Orion Delta is different to the STL files I can find online http://repables.com/r/171/
Essentially it's an enclosed tube to the tip on the above version its open on the lower side.
Enclosed blower to the tip
But the one I can find online is open on the lower face (towards the print giving general part cooling and not as direct)
STL with open face
STL with open face
So I'm after the STL file for the blower I've got fitted as it works fine but I'm adding a retraining clip and going to improve the fit.
I suppose I could easily add the face myself but the file must already exist..... It' s not on my SDCard just the Peek fan GCO.
Any help appreciated.
Cheers.
Re: Blower Mount STL Files
Posted: Sun Oct 26, 2014 10:13 am
by Mac The Knife
Here you go,,, I forget where I found it at,
Posted: Sun Oct 26, 2014 5:57 pm
by RocketMagnet
Yes that's the one.. thanks.
Posted: Tue Dec 02, 2014 4:56 pm
by Holy1
RocketMagnet wrote:I'm looking to print out a replacement blower mount with a tiny mod. However the Stock blower on my Orion Delta is different to the STL files I can find online http://repables.com/r/171/
Cheers.
Does anyone have the .igs file for this? Couldn't find it on githubs . Thanks
Posted: Wed Dec 03, 2014 10:02 pm
by Holy1
Just bumping this.
Posted: Wed Dec 03, 2014 10:17 pm
[quote="Holy1"][quote="RocketMagnet"]I'm looking to print out a replacement blower mount with a tiny mod. However the Stock blower on my Orion Delta is different to the STL files I can find online http://repables.com/r/171/
Cheers.
These are what I found:
http://repables.com/r/212/
http://www.thingiverse.com/thing:487768/#files
Posted: Thu Dec 04, 2014 11:40 am
by Holy1
Cheers.
Thanks Eaglezsoar, I had the .stl but wanted the step or iges file.
Posted: Sat Dec 20, 2014 12:35 am
by TFMike
Don't mean to necro this but I am in the process of switching to PLA printing for large parts, I printed this out in ABS and I attempted to mount it to my effector with no luck, I bought my Orion in oct/nov of last year, perhaps the effector heads have changed since then? Here is a pic showing what I am talking about:
Posted: Sat Dec 20, 2014 1:27 am
by bot
There should be a plastic tab on the effector that fits into a slot on the shroud... It looks like you maybe have just put a screw through the tab into the hole?
Posted: Sat Dec 20, 2014 1:45 am
by TFMike
bot wrote:There should be a plastic tab on the effector that fits into a slot on the shroud... It looks like you maybe have just put a screw through the tab into the hole?
There is no plastic tab and even if there were, look at the height of the blower compared to the print head, its not lining up on this machine, is my model too old or something?
EDIT: Look at the effector platform in the first picture in this thread and then look at mine, they are not the same. I don“t know what to do, any help?
Posted: Sat Dec 20, 2014 6:03 am
by RocketMagnet
yeah that looks different to mine
Tab to connect Blower
how it pushes on to the tab
Pushed into position without screw in place
This is the platform on mine: http://repables.com/r/294/
I've seen a few other blower mount designs for example
http://www.thingiverse.com/thing:74789
http://www.thingiverse.com/thing:110305
Looks similar to your plate?.. but I'd not use a fan setup like that myself, a blower is better for that task IMO.
So part 110305 looks the same as yours, so you could always download it and combine its mounting system to the blower in your preferred cad.
Posted: Sat Dec 20, 2014 12:07 pm
by bvandiepenbos
TFMike,
you have the original 2 piece effector platform so yours does not have the fan mount tabs as new platform does.
This fan shroud will work on yours http://repables.com/r/399/
or this
