HPX2 Dual Extruder
Posted: Thu Oct 30, 2014 11:09 am
by longshot
Have any of you guys seen this? I tried to do a search but came up empty.
http://www.dglass3d.com/
They feature a product called an HPX2. Its a dual extruder with an autolift feature. I think if this works on our rostocks it would a pretty neat and easy upgrade for a dual extruder setup.
I'm using a dual extruder setup myself but the shimming, calibrating, etc is always difficult and I'm still tweaking it. This seams like win win if it works. Gap distances are known, a moving nozzle means you'll never snap the part as the 2nd nozzle brushes over the part.
The problem I can't understand is its a single motor, dual extruder. Their forums and support seems limited so I have no idea how its wired. The technology reminds me of the Stratasys systems with their Uprint or larger fortus machines as they have a retracting nozzle heads.
Any thoughts? Good bad? Try it out? Thoughts on wiring?
Re: HPX2 Dual Extruder
Posted: Thu Oct 30, 2014 12:18 pm
by Mac The Knife
I don't see where the extruder lifts, they do say infinite retractions,,,, but that is done in software. The servo they show on their HPX2-MAX is how they are using one motor to drive both filaments,,,,, it is being used to shift gears.
Posted: Thu Oct 30, 2014 12:27 pm
by Mac The Knife
I did find this,,,, lunch time is over, but it looks like they are using the filament to retract the spring loaded hotend? Kinda like using the molten filament as a hydraulic fluid?
https://www.kickstarter.com/projects/dg ... s?ref=card
Posted: Thu Oct 30, 2014 6:37 pm
by bubbasnow
yes they are using the force of the coldend extruder and filament to force the hotend down. when a retraction occurs its pulls out filament and relieves for spring and pulls the nozzle back up to an adjustable height
Posted: Thu Oct 30, 2014 7:13 pm
by Generic Default
So the retraction must pull the filament all the way out of the barrel to activate the mechanism? That thing looks awesome, I just don't know about the price with how many machined metal components it has. Those parts look like they can't be mass produced on a bar fed lathe, and milling costs are usually higher because of the added labor for switching and positioning parts. Maybe if they're flat they can be AWJ cut.
Posted: Fri Oct 31, 2014 3:08 pm
by longshot
On the Hpx2-Max:
The thing the bothers me is the wiring. How does one hook this in if they have a ramps? I see where the extruder is wired, but there is a servo that is attached that will switch the filament. How does repetier know to move the servo over? Are we talking firmware rework?
HPX2:
The HPX2 seems like a better fit for the Rostock. It features 2 extruders (we already know where they go on the ramps). And if what is above is true then retraction will force the nozzle up.
As a side note, for traditional dual nozzle setups . . . is there some kind of auto retraction of the nozzle not in use before the primary nozzle comes online?
