Page 1 of 2
Building Betsy. A RMv2 build log
Posted: Sat Nov 08, 2014 4:09 pm
by Kitecraft
Step 1: Remove from box (I really don't know why I thought it came with a roll of filament)
[youtube]http://www.youtube.com/watch?v=XbMHwi11i7w[/youtube]
Re: Building Betsy. A RMv2 build log
Posted: Sat Nov 08, 2014 4:10 pm
by Kitecraft
Episode 1: Prep work.
[youtube]http://www.youtube.com/watch?v=nte5zo6DlgE[/youtube]
Posted: Sat Nov 08, 2014 4:38 pm
by crocky
What fun....
It's worth it in the long run :)
You really should have a better light to be doing video's, good subject but it is just a little hard to see at times.
Keep up the good work :)
Posted: Sat Nov 08, 2014 6:53 pm
by Kitecraft
crocky wrote:You really should have a better light to be doing video's
Yep, I should :(
Thanks.
Posted: Sat Nov 08, 2014 7:15 pm
Your videos are fine and I personally appreciate the time it took you to make them.
Could they be better? You bet, but so can a 2015 Corvette.
I agree with crocky, keep up the good work!
Posted: Sat Nov 08, 2014 11:20 pm
by Kitecraft
Thank you.
Episode 2: Solid foundations to build upon.
[youtube]http://www.youtube.com/watch?v=2KOnazL4OSU[/youtube]
Posted: Sun Nov 09, 2014 10:45 am
Excellent work! :) Where'd you find the mesh loom material?
I should have the final assembly chapter (wiring) done today and I'll get it uploaded as soon as it's done. You might want to download the current version - the paging will be better.
Thanks for taking the time to do the videos and for being brave enough to beta test my 2nd edition. :D
Edit: FYI, SeeMeCNC injection molds all the plastic parts on-site as well as laser cuts all the Melamine parts. There's very little in the kit that are "buyout" items.
With your speech cadence and accent, it's almost like watching an episode of the Red Green Show. Awesome work man! :D
Posted: Sun Nov 09, 2014 3:03 pm
by Kitecraft
That made me laugh! Red Green :)
I found the wire mesh loom at a store here called Princess Auto of all places.
I've been in software QA and testing for 15 years. Reviewing documentation is nothing new :D
Cheers.
Posted: Sun Nov 09, 2014 3:40 pm
by Kitecraft
Episode 3: The Onyx hot bed. :D
[youtube]http://www.youtube.com/watch?v=5CGp-fJU5t0[/youtube]
Posted: Sun Nov 09, 2014 10:10 pm
by Kitecraft
Episode 4: Building tall and strong.
[youtube]http://www.youtube.com/watch?v=tuUcwCU1i1Y[/youtube]
Posted: Mon Nov 10, 2014 10:26 pm
by Kitecraft
Episode 5: Building the fun and interesting bits like the hot-end, platofrm, cheapskates, drive belts and top section.
[youtube]http://www.youtube.com/watch?v=sP8gPiYMMuc[/youtube]
Posted: Mon Nov 10, 2014 10:32 pm
Having the top plate flipped won't cause you any problems at all. You'll just have the extruder mounted on the left instead of the right. That's actually how it's shown on the SeeMeCNC website. :D
The full assembly portion is done now and all of the ugly paging errors are gone.
Posted: Mon Nov 10, 2014 10:48 pm
Just got to the point in the video where you've mounted the EZStruder. Because you installed the top plate flipped, the hole for the filament is now on the back side of the location where you've got the EZ installed. You'll need to move it to the other location in order to get the filament feed hole lined up with the top of the extruder. Sorry! :(
Posted: Mon Nov 10, 2014 11:25 pm
by Kitecraft
Thanks. And ya, I figure out about the hole afterwards as well :)
I was just gonna drill a new hole. :shock:
I'm about to mount the Rambo. As it happens, I have some 2mm spaced male headers. Instead of soldering the fan wires directly to the board, I get to keep the plug and just use headers :D Rather happy about that luck.
Cheers,
Posted: Tue Nov 11, 2014 1:16 am
by teoman
That is what I did as well.
Posted: Tue Nov 11, 2014 9:41 am
Most people don't have two pin headers handy and I'm not about to specify more "additional" stuff to give people something else to whine about. :D
Posted: Tue Nov 11, 2014 3:25 pm
by Kitecraft
Well that didn't work as well as I had hoped.
When booting, the 'NOZ' value flashes 366 (not a negative number), then both NOZ and BED go to 'def'.
While trying to examine the hotend thermistor, after untapeing it (do we really need to wrap the whole end it tape???), the termistor pulled out of the hot-end.
I don't know even know what to do now. :(
Posted: Tue Nov 11, 2014 3:43 pm
by Kitecraft
When only the bed is plugged it, it works fine. Even heats up when I put my fingers over the top and bottom.
So, it's clearly the hot-end that is messed up. But I can't see another. Heck it's even been pulled out of the hot end and I can that there are no leads touching or anything.
Can I buy new thermistor direct from SeeMeCNC? I'm guessing I've screwed up this one now.
Posted: Tue Nov 11, 2014 3:45 pm
by guanu
over 300 = wires shorted together.. negative means open or broken wire..
so you had the 2 wires touching... and its fine the thermistor pulled out of the hole, just fish it back in and kapton tape it to the crimp so it doesnt move, not like you should be poking around the heating block when you got the machine going so as long as its in there and cannot move, you will be fine
Guanu
and to edit, yes we sell thermistors... http://seemecnc.com/collections/parts-a ... r-100k-ntc
Posted: Tue Nov 11, 2014 3:48 pm
by Kitecraft
I can't find any short anywhere. :(
And, shipping costs for one theremistor is twice as much as the thermistor itself. :( Double sadness!
Posted: Tue Nov 11, 2014 3:59 pm
by Kitecraft
Oh my GOD I am such an idiot!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
<sigh> found it.
I hate myself so much right now.
Posted: Tue Nov 11, 2014 4:58 pm
by Kitecraft
Yep, fixed it. <geez>
So, while I wait for the RTV to set now that I've re-installed the thermistor in the hot-end, I went through the first steps of verifying the software and operation. I guess it was a good cookie day.
I'll be posting Episode 6 of my build log soon.
I guess this means I'll do the final calibration tomorrow after I re-install the hot-end once the RTV has set (again).
Cheers.
Posted: Tue Nov 11, 2014 5:47 pm
by nitewatchman
Kitecraft wrote:Oh my GOD I am such an idiot!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
<sigh> found it.
Sooooo - What was "it"?
Posted: Tue Nov 11, 2014 5:54 pm
by Kitecraft
Welllll
I sorta might've could've happened to have maybe forgot to perchance put heat shrink tubing over both leads before, errrm, sleeving them. This is on the other end where you plug the lead into the motherboard. The hot-end was fine.
Posted: Tue Nov 11, 2014 7:00 pm
by nitewatchman
I hate it when that happens!
I try to blame it on my wife for distracting me with dinner or some other nuisance like that.
