Damper audio comparison...
Posted: Sat Nov 15, 2014 6:42 pm
I got the Astrosyn dampers installed on White MAX, the machine built for the 2nd Edition of the Rostock MAX v2 assembly manual. Here's a short video that demonstrates the before & after change to the sound the machine makes.
Thanks for lightninjay for posting the gcode file I used.
Here's the video: http://youtu.be/OfobfmrimuI
Re: Damper audio comparison...
Posted: Sat Nov 15, 2014 7:16 pm
by Captain Starfish
Nice.
What the video, with a microphone up next to the printer, doesn't convey is what the sound is like six feet away or in the next room.
I can sit and work in the same room as the printer, and sleep in the next room without being disturbed by the noise now that the Astrosyns are installed.
Posted: Sat Nov 15, 2014 7:46 pm
by Holy1
Posted: Sun Nov 16, 2014 7:48 am
The video Gene posted certainly gives a user a reason to buy the dampers.
The difference in sound with and without the dampers was dramatic.
Good job, Gene.
Posted: Sun Nov 16, 2014 3:54 pm
Thanks, Eagle.
The funny thing is, I only installed them to show how they were installed. The noise doesn't bother me at all. I spent most of yesterday with two un-damped machines printing in the same room with me. It was no biggie. :)
Posted: Fri Dec 19, 2014 3:37 am
by lightninjay
Ha! I just got around to finding this thread!
That's too funny Gene, glad you liked my file enough to use it for your demonstration. :)
Posted: Fri Dec 19, 2014 9:55 am
by Flateric
Here's another example, although not nearly as cool but hey....
http://youtu.be/hjvHbvPFEqM?list=UUBaX2 ... XBhJrmQPQQ
Posted: Fri Dec 19, 2014 10:17 am
The Imperial March is *always* the right test file. :D
Posted: Sat Dec 20, 2014 8:37 am
by add1ct3dd
How easy were they to install? Got mine today. Presume it's just a case of slackening up the belts at the top, undo the bottom bolts holding the stepper, move the pinion further out to accomodate for the dampers, and then reinstall and tighten up?
Will be doing mine tomorrow most likely.
Posted: Sat Dec 20, 2014 11:06 am
by BenTheRighteous
In theory, that's all it takes.
Mine did not go that smoothly. :)
Posted: Sat Dec 20, 2014 11:38 am
by Captain Starfish
I didnae even have to slacken off the belts, was easy peasy:
- unscrew stepper motor, winkle it out.
- push the pulley out 7mm further along the shaft, it just fits.
- reinstall on the dampers, a screwdriver can be used to loop it around the pulley again if you can't get the required angle of the dangle.
Posted: Sat Dec 20, 2014 2:21 pm
by add1ct3dd
Angle of the dangle, I like it!
Cool, hopefully do that tomorrow :).
