calibrating via pressure sensor
Posted: Fri Nov 21, 2014 4:44 am
by SirLinhart
Has anyone used something like this: https://www.sparkfun.com/products/11207 ... fgodrQ4A_g or maybe some sort of displacement sensor to get an idea of where my calibration is without using the paper? I also need to know if the offset from testing(since this will be higher than the actual base) will muck with the overall calibration.
Re: calibrating via pressure sensor
Posted: Fri Nov 21, 2014 5:37 am
by teoman
Yes.
That is a current topic. Ceck out the last 2 pages of posts. Also check Nylocke's posts. I believe he is implementing a setup with similar sensors.
Posted: Fri Nov 21, 2014 7:24 am
by SirLinhart
I will take a look, thanks
