Orion Hotend - Cartidge Heater? Size? Good idea?
Posted: Sat Nov 22, 2014 8:18 pm
by peterdaly
In the previous thread, I noted I blew the heating resistor...
Need something I can get fast an cheap...Amazon Prime is ideal.
Just found a thing on Cartridge Heaters vs. Resistors. Seems easier for a novice to switch out fast...no?...with better precision and life. ??
Is one easy to swap in? Attach to existing resistor leads? Is it a bad idea? And a very key question...what size?
Would this work?
Specification: 24V/40W
Diameter: 6mm
Cable length: 1M
Material: Stainless steel
http://www.amazon.com/Kamo-2pcs-Cartrid ... 6V5HQ222X8
[img]http://ecx.images-amazon.com/images/I/4 ... 0,100_.jpg[/img]
Re: Orion Hotend - Cartidge Heater? Size? Good idea?
Posted: Sun Nov 23, 2014 3:12 pm
Your choice of cartidges are 24V and will not work on a Rostock.
You need this type: http://www.ebay.com/itm/2-PCS-Reprap-12 ... 339286131c
You would remove the resistors and insert ONE of the cartridges into ONE of the holes on the hotend , the other hole would be empty.
Add the appropriate connectors and you will be back in business.
Posted: Sun Nov 23, 2014 10:19 pm
by Nylocke
What, Eagle, you want to be safe? You don't want 3 second heat up times? You don't want a fire hazard risk? That sounds crazy to me!
Posted: Sun Nov 23, 2014 10:24 pm
by nitewatchman
Posted: Sun Nov 23, 2014 11:47 pm
Nylocke wrote:What, Eagle, you want to be safe? You don't want 3 second heat up times? You don't want a fire hazard risk? That sounds crazy to me!
I try to err on the side of caution, I have had too many exciting times and have decided to think before doing. :)
