Adding a second layer fan to Orion
Posted: Mon Nov 24, 2014 11:17 am
by deager4
IS there any way to add a second layer fan to the Orion? Just wondering. Thanks.
Re: Adding a second layer fan to Orion
Posted: Mon Nov 24, 2014 11:39 am
deager4 wrote:IS there any way to add a second layer fan to the Orion? Just wondering. Thanks.
You can print another fan shroud for the layer fan: http://repables.com/r/212/
Click the arrow on the right of download to get just the stl.
You also will need the fan which is here: http://seemecnc.com/collections/parts-a ... blower-fan
Posted: Mon Nov 24, 2014 11:42 am
by guanu
here is the current version of the blower shroud...
Guanu
Posted: Fri Dec 05, 2014 11:55 am
by deager4
Thanks how would I wire the second fan?
Posted: Fri Dec 05, 2014 12:09 pm
deager4 wrote:Thanks how would I wire the second fan?
The second fan is wired in parallel with the first fan.
Posted: Fri Dec 05, 2014 1:58 pm
by deager4
Could I in theory wire three of the together without drawing too much current? Thanks.
Posted: Fri Dec 05, 2014 2:03 pm
by Mac The Knife
deager4 wrote:Could I in theory wire three of the together without drawing too much current? Thanks.
Yes you can, I currently run three hooked together in parallel.
Posted: Fri Dec 05, 2014 3:30 pm
I run 3. Mainly for symmetry / even coverage.
Fans require very little power, so you're fine.
