Weird .92 homing behavior?
Nylocke
Post by Nylocke »
It doesn't always happen, but when I home my printer sometimes it will make this loud slamming noise. I only noticed it after installing .92 repetier. I'm sure if I were to switch back it would be fine. Its like something is bumping the carriages/effector when it moves into the extruder offset position and moving them all <1mm down. This makes things very frustrating, I've had to restart the same print several times just to get a good first layer.
I did notice if I lightly held my hand against the effector it wouldn't make the noise and it wouldn't move down. One of the times I did this (at the beginning of a print) I, while applying very little pressure, was able to push the whole carriage assembly towards the Y tower. This was completely accidental, and was caused by me just trying to keep very light pressure on the effector to prevent the issue. I'm wondering if there is a bug that causes the stepper drivers to limit (or even cut out) the amount of current going to the steppers directly after a G28 command? Or maybe its simple as my stepper drivers are broken? I have some new fancy ones coming in from Panucatt so that second option will be tested out sometime soon.
Does anyone know what could be causing this?
rpress
Re: Weird .92 homing behavior?
Post by rpress »
I've been running 0.92 for a while now, and while I see other issues I see nothing like what you see. I don't have any extruder offset so it's possible that the offsetting move has too high acceleration/velocity?
Nylocke
Post by Nylocke »
That is also a possibility. Not sure why it would show up on a firmware change, the settings are (or should be) the exact same thanks to EEPROM. I was at around 8 days worth of printing, and it'd probably been homed over 100 times with all that calibration, I'm sure it would have reared its head if it wasn't related to .92?
