Changing the Beeping Sounds
Posted: Thu Nov 27, 2014 5:55 pm
by tamcofarms
I saw a video awhile ago where someone changed the beeping played when starting a print from the standard multiple beep to sound like R2D2. Any clue or documentation as to how I could do something similar. Mainly I figured if you could do it at the beginning with a 'tune' then you should be able to add some kind of fanfare to celebrate that the print job is done at the end.
Re: Changing the Beeping Sounds
Posted: Thu Nov 27, 2014 10:03 pm
by emile1138
I am also now interested in such things.
Posted: Fri Nov 28, 2014 6:06 am
by bot
I would have figured you were the one with the R2 sounds to begin with!
Posted: Fri Nov 28, 2014 7:00 pm
by emile1138
bot wrote:I would have figured you were the one with the R2 sounds to begin with!
I take this as a compliment, and a fantastic one at that! Thank you! Lol
Posted: Fri Jul 03, 2015 11:24 pm
by DarrenAnton
tamcofarms wrote:I saw a video awhile ago where someone changed the beeping played when starting a print from the standard multiple beep to sound like R2D2. Any clue or documentation as to how I could do something similar. Mainly I figured if you could do it at the beginning with a 'tune' then you should be able to add some kind of fanfare to celebrate that the print job is done at the end.
Here...
https://www.youtube.com/watch?v=ITXavSI ... ploademail
http://ddrboxman.github.io/RepRapRingtone/
http://arcadetones.emuunlim.com/arcade.htm
Posted: Fri Jul 03, 2015 11:44 pm
by IMBoring25
Every time I tried to change the frequency of the stock Rostock beep/buzz, the pitch didn't actually change. I got it to do a few different variations of things that sounded like flutter-tonguing a brasswind instrument, but it was always at its core the same pitch.
