Filament Humidity Question
Posted: Tue Dec 02, 2014 4:18 pm
Hello All!
By putting together things I've read from various threads, I realized that a lot of my printing problems were likely due to moist filament.
I purchased my Rostock with a 2 pound spool of ABS. In my excitement I opened it all up. It took me nearly a year to finish my Rostock, and that whole time the ABS was out in the shop, exposed.
I also had a brand new roll of Taulman 618 that was still wrapped in plastic, but not vacuum sealed.
I have not actually printed with it yet, so I cannot say if it's suffering from moisture or not, but from everything I've read, the Nylon is very hygroscopic, and so there is good chance it needs drying. I'm essentially giving up on the ABS for right now, and looking at switching over to the Nylon. So of course, I want to make sure the Taulman is dry enough that it's not going to give me poor results that I could mistake for calibration problems.
I have no oven that I can use for drying purposes at the moment, so here is what I have done instead:
I have bought a hygrometer, put the filament spool in a zip lock bag with desiccant crystals (I used Fred Meyer's store brand kitty litter crystals) and zipped it up, then put the bag inside of an airtight plastic box. It has sat about week. The hygrometer is still reading around 52% humidity. Is this normal? I saw others talking about getting 15% RH with their spool enclosure.
I guess the real question is, what am I looking for in terms of RH, is my method even going to be effective enough, and of course, are there are any better ideas out there?
Thanks in advance!
-Daniel
Thanks in advance!
-Daniel
