Filament for latch
jdurand
Filament for latch
Post by jdurand »
A client is interested in a run of printed latches for his product. He can't find what he wants commercially and his volume is too low to make a mold...so he asked me.
This is the snap-latch type, push into receptacle and and it snaps locked. Press lever and it unlocks.
I'm thinking of graphine filament, instead of bending maybe make it pivot with a spring? Or...is the stuff flexible? How hard is it to print? Any other suggestions?
0110-m-p
Re: Filament for latch
Post by 0110-m-p »
I would use nylon for this. It is quite flexible without being too weak. It is also very tough and abrasion resistant so perfect for a slide/clip style latching mechanism. Nylon is also easily dyed whatever color you need.
Only caveats are that nylon requires an all metal hotend due to 260-280C extrusion temp and the filament must be dried before printing.
jdurand
Post by jdurand »
I just received the mating bit this latch has to ... well ... latch onto. I see some possibilities for how to do this. I'm going to try some PC-ABS and some graphene-PLA for the prototypes. I Realized the PC-ABS needs 260-280C at the print head so while waiting for my E3D head I can try this in my Afinia that prints their high-temp ABS at 260C. Hopefully it doesn't jam up, the Afinia is picky.
Any ideas for holding a metal pin like a dowel pin into a print? The head has to be exposed. I was thinking of a PEM-MPP pin pushed in from the back with some way to capture it.
Return to “Filament”
