Config file for Repetier firmware builder
Posted: Fri Dec 05, 2014 4:26 pm
Has anyone created a config file for using Repetier's firmware builder on the website? I'd love to play around with V.092 and keep up with the more current revisions.
http://www.repetier.com/firmware/v092/index.html
I'm currently running "stock" Rambo electronics, and would love to have a starting point to jump off of.
Re: Config file for Repetier firmware builder
Posted: Sun Jan 18, 2015 10:42 pm
by briankb
I second this request.
Posted: Thu Feb 05, 2015 3:18 pm
by Nylocke
I posted one in my build log. You'll need to scroll down a bit http://forum.seemecnc.com/viewtopic.php ... &start=175
Let me know if anything needs changed
Posted: Tue Feb 17, 2015 6:35 pm
by Nylocke
Known working config file. Just rename to configuration.h
Posted: Wed May 20, 2015 9:57 pm
by Jrjones
How do you set the Z height with v0.92.3 ? I swear I saw it briefly in the LCD menu, but can't find it anymore.
I've got it set via the EEPROM but its far easier to adjust it via the LCD.
Posted: Thu May 21, 2015 8:14 am
Jrjones wrote:How do you set the Z height with v0.92.3 ? I swear I saw it briefly in the LCD menu, but can't find it anymore.
Not sure about which exact version I'm running, but on mine it's: click, scroll to advanced settings at the bottom, click, scroll to set z height at the bottom.
So go to the bottom of the menu list, two layers deep, and you'll find it there.
Posted: Thu May 21, 2015 2:48 pm
by Jrjones
Ah, I got it.
I had changed the Z_HOME_DIR to 0 because I thought it was making the carriages move up into the limit switches after homing. But it also turns off the Z Calibration menu if its set to zero.
