Help Needed - New Build: Power Issues Part 1
Posted: Sat Dec 06, 2014 8:16 pm
Hi guys,
My (mechanical) build of the MAX went well with no issues. Powered up and proceeded thru the instructions.
Stuck with one isuue: with one or both sets of red & black heater wires screwed into the Rambo I cannot adjust its temp settings without a shutdown both rambo & P/S.
The x, y & z axis end stops were reporting h's when queried with the the M119 command. I checked everything until I found that the pins in the connectors on the rambo board were not making contact. No amount of force, wiggling, or jiggling could make it work. In my 1st attached picture below you will see that I removed the pins from the plug in connections and inserted them directly into the female socket. This caused all axis to report L's as needed. The thermistors both were reporting ~23C, but when I tried to turn the heat up (or on) the control panel shut down. This was true if I did it on the max lcd panel or thru Mattercontrol. The bed heat led will not come on. I pulled the bed and there were no wiring issues, bridges, shorts, or broken connections. I checked all the plug in & screw in connections on the rambo board but the issue persists. Again this issue is true of both the hot end and bed heat. All fuses were checked several times and are good to go. Again, no amount of force, wiggling, or jiggling could make these connections work. So is my p/s supplied with the kit underpowered?
Thanks in advance!
Thanks in advance!
